First post, by OldDosFan
I am going to be figuring out how to use DosBox in Linux, don't worry, i'm a lean keen figuring out how to use linux machine 🙄 . I have already asked some questions about this, and as suggested, rest assured I am in the process of learning.
But in the meantime I have installed DosBox In windows, and I can not access the disk drive or even the hard drive. I therefore cannot install programs, and i'm not sure if i'll be able to use them. I can only access the z drive .. z:\. Could you please help to access the disk drive.
I want to first install Turbo C++ for Dos from the floopy disk drive. 😐 😀 😘
