First post, by rh
hi!
i have a weird problem with the new 0.61 version (did not happen in 0.60):
when using the text mode (on command line) oder 640*400 svga graphics mode (in game) this works perfectly as long as using dosbox in a window.
but when switching to fullscreen, then only a part of the screen is being displayed: at the bottom and the right border a piece is missing and is just black (no the problem is not that my monitor is badly calibrated, i can see the area, but all pixels are just black). 😢
any ideas? thanks a lot!
regards,
rh
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
consider it a feature of dosbox. I don't feel like explaining it alll
Just search this forum. I'm sure it's discussed a few times.
Water flows down the stream
