First post, by Guest
Guest
Offline
Use it for MODs and the like, but not for MIDIs. It's not an emulation issue, it's just Cubic Player that plays the instruments totally wrong, and I mean REALLY wrong 😖 : shorter length, incorrect ADSR times, shifted frequencies...
I tested version 1.7 of Cubic Player with some of the MIDIs that come with the Ultrasound software and there is a huge difference between PLAYMIDI and Cubic Player. Just test them both with STRIVING.MID or SOFUNKY.MID, you will hear the difference. Use "playmidi -video" command to avoid that ULTRASOUND hi-res screen which slows down the emulation 🙄 .
