First post, by Condor-2-4-2
Hello,
I tried to run the Catacomb 3D-Games in DOSBox SVN Daum r3894 and got a strange graphic behavior. In the attached screenshot you can see the starting level of Catacomb Abyss, but the screen is verticaly stretched and the bottom menu and item bar is not shown. I tried several graphic modes and resolutions, but the result is always the same.
Then I tried the game with the original DOSBox ver0.74 and the screen is correctly shown (I used even the same graphical settings like in the SVN Daum Version).
Other games like Blake Stone or Corridor 7 are working correct with DOSBox SVN Daum.
Is there anybody who uses this DOSBox version and has an idea how to solve this graphic error?
Thanks for your reply.
Greetings,
Condor-2-4-2
