First post, by pjburnhill
Is it just my config or is there something wrong with VLC 2.2.1 regarding DosBox Capture Codec (ZMBV) not playing back?
All I get is blank (black) screen with the in-game audio working fine. MPC-HC plays the videos fine without issues.
I've installed the ZMBV codec from DosBox install and restarted, reinstalled VLC deleting prefs+caches.. still not working.
So are others having similar issues with VLC 2.2.1 or is it just me?
Cheers,
PJ
Reply 1 of 6, by VileR
Not just you... it's a bug with 2.2.1, reported it myself a while ago: https://trac.videolan.org/vlc/ticket/14975
Reply 3 of 6, by Great Hierophant
The comments suggest using VLC 2.2.3, but if anything the problem is worse in that version.
Reply 4 of 6, by Great Hierophant
It turns out that VLC does not like the decoded format for native DOSBox recorded video. DOSBox uses "Palettized RGB with palette element R:G:B." What I have done was to run the video through VirtualDub, use the ZMBV codec at 32-bit color depth and do whatever else I want to it. If the decoded format is "16 bits RGB" or "32 bits RGB", you should be good.
Although 32 bit increases the file size a little relative to 16 bit, when capturing VGA it is best to use 32 bit. VGA selects 256 colors from an 18-bit palette, so 16 bit color may lose a bit of fidelity.
Reply 5 of 6, by Great Hierophant
This issue has been fixed in the VLC 3.0 nightly builds. 3.0 also restores support for MIDI through FluidSynth, but you will need a soundfont .SF2 file. Not perfect but better than nothing.
Reply 6 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Thanks for the heads up!
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
