First post, by olddosuser
I know that Windows is not officially supported by DosBox, but I am hoping for some help anyway. I was able to get it in installed and running. I created an image file and installed it in there and boot the image file and it works.
However, there are 2 problems. 1) My cd-rom drive is not listed in windows 95B. I figure this is because the are no 95 drivers for it. I do have am image of the CD-Rom game. I tried to mount the iso file to a drive letter with the -t parameter, It mounted, but when I start windows 95, it does not see it. I mounted my physical cd-rom drive and booted into Windows, but it did not see that either. I tried to use the -aspi parameter, but I got some kind of error message. Can't remember what is was. Is there a way to mount my drive or image so that windows will see it. I prefer to use the image file.
Problem 2) I have a Logitech Xbox f310 game controller. Is there a way to get windows 95 to see it. I know that 95 does not support usb, but I thought since DosBox emulates the gameport, that Windows would see it. There are no 98 drivers for it; so installing 98 in DosBox probably won't work. I already tried installing 98 in VirtualBox and did not get the controller working. It did see it, but without the drivers, 98 would not configure it. Does anyone have suggestions? I do have an old controller with a gameport connector. I thought about getting a gameport to usb adapter, but I know those things are hit and miss. I suppose I could try to find an old controller with 98 drivers. Btw, I did try XP drivers in the 98 VirtualBox; did not work.
I would appreciate any help in these 2 problems. This is the only Windows game that I miss playing. All my other games runs in Dos and DoxBox works perfectly for them. I have tried using the compatibility mode with no luck. I have not been able to play this game since windows 98. I never even got it to work in XP. I am currently on Windows 10.
