First post, by othest
my dosbox is keep using lame primary config and not uses my prefer config please help me
version is 0.73, os is windows 10
1. use 0.74 or even better a SVN built
2. read the readme on how to point Dosbox at another config file
well it didn't worked.
and no, i don't wanna use svn build or new version.
"It didn't worked" is a very bad description of what happens. If you don't want to use a newer version you are on your own, seems you don't need help after all. Good luck.
wrote:my dosbox is keep using lame primary config and not uses my prefer config please help me
place DOSBox to a folder like c:\games\dosbox, copy there dosbox.conf and run dosbox.exe
send all your pleasure with using of Win-Spy-10 to MS
Thanks Tertz!!!
