And here is the last question, and the answer will decide if I actually go on with
what I am doing, or not.
Not would be not great, as I allready spent a lot of time to make this work.
Anyways:
I am using an old shareware menu program called G-Menu for my whacky frontend,
I use it to launch all the games and also my batch files for the settings.
If you are asking yourself why, I like this just for old school 90s feel.
G-Menu is the best I found amongst ~50 old shareware menu programs.
I tested it a LOT, before I started this. No game has a problem with it.
It has this wonderful "leave G-Menu resident" option - if unchecked, its slower, but no memory is used.
I am aware that it has to be -somewhere-, as it re-launches when a game closes.
All config -get and config -set options work flawlessly.
As said, I allready testet it many many times.
As I mentioned above, I try to use ASET to set Variables....
this only works outside G-Menu. From inside, it just delivers an empty string.
SET VAR=example works normally for example.
This shows me, that a basic thing is going wrong here - is that a problem
of G-Menu or ASET?
If I still would be 12 years old, I would probably try and try and try to find it out,
but I am a bit older right now, having a lot of things to do and maybe someone here
can shorten this and help me...
edit: my 12 year old self was clever enough, to find it out (seems like)
G-Menu loads the VARs on startup, but doesnt update them until next restart.
(when I quit, they are there)
Huge drawback 🙁
edit2: ... but this is actually normal behaviour.
but ASET affects the master environment.
things coming back ... SLOWLY. Makes fun again.
When this is done, I will post it. 😀
