Doom - Dosbox - Boom
First post, by ravenxau
Hi All,
First post here - I thought I would share a neat little setup to run Doom using the dos version of Boom 2.02 and DosBox
First set up a new folder with all these files:-
boom.exe
cwsdpmi.exe
doom.wad (or doom2.wad, doom1.wad,etc...)
dosbox.exe
dosbox.conf
sdl.dll
sdl_net.dll
Now for the cool bit:-
edit the dosbox.conf file with notepad so the only text in it is as follows...
[sdl]
fullscreen=true
[render]
scaler=2xsai
[autoexec]
mount c .
c:
boom
exit
this will start doom when you run dosbox in full screen mode - the 2xsai scaler gives a nice smoothed out display that almost looks high resolution without any extra wad files
the mount c . tells the system to mount the local folder as dosbox's game folder. This makes the whole setup portable for running from a flash drive
you may need to use the -IWAD parameter in dosbox.conf depending on which IWAD you are using (I have successfully tested with doom.wad and doom1.wad)
Give it a try and tell me what you think.
Reply 1 of 7, by leileilol
or just .bat or shortcut this:
dosbox.exe -exit boom.exe
long live PCem
Reply 2 of 7, by ravenxau
leileilol wrote:
or just .bat or shortcut this: […]
interesting approach....
Reply 3 of 7, by Jorpho
Why use DOSBox at all, when there are surely a multitude of other Doom ports for Windows that work just as well and probably also implement 2xsai?
Reply 4 of 7, by keenmaster486
Why use real hardware at all, when you have DOSBox?
This is the spirit of things, man!
World's foremost 486 enjoyer.
Reply 5 of 7, by leileilol
Or maybe he/she wants to use Boom and only Boom.
Being part of the doom community for over a decade I can perfectly understand the motivation for running Boom in an emulator, especially when there's a large community of mappers working in the bare specific-engine-cruft-free Boom standards, one would want to test their maps in Boom to ensure it plays like it should, and in a convenient way this thread is about.
You'd also be surprised to know there are hardcore mappers still targeting the original DOS executables with all their tricks that a "modern" sourceport would fail in one way or another.
long live PCem
Reply 6 of 7, by Jorpho
I thought that's what "Chocolate Doom" was for. Or is that still not perfect?
Reply 7 of 7, by ravenxau
"Choco" works fine - as does ZDoom, Doomsday,etc.....
I just thought I'd share what I had learned tinkering around with dosbos and various dos based source ports
I must say as a "Knee Deep" fan, I like my setup fpr playing the old vanilla wads from the 90's
latest plays are :- Slaughter Until Death (which I like to think of as the original "Thy Flesh..." and IMO better as well) and Enjay's "Come Out Fighting"
