First post, by glboater
I found DOSBox and love it, it helps me run an old Dos program I've used for years but have a problem. I created either a config or bat file to open this particular program but for the life of me can't find where it's located. Can someone give me a hint where I can look ?
Thanks in Advance
Reply 1 of 4, by Errius
Have you looked in your AppData/Local/Roaming folders? Installers sometimes put programs in there for some reason I don't understand.
Is this too much voodoo?
Reply 3 of 4, by lightmaster
Maybe it's for Vista+ O.S. compatibility..
