First post, by Guest
How can edit those files for DOSBox? The reason I ask is because I need to load Soft-Ice for DOS as a device using the statement:
device = c:\cracking\s-ice.exe /SYM 50
I can't figure out where or how to insert that statement, which is supposed to be in config.sys.
Pentium
2 Ghz
Windows XP
I have read README already.
Reply 1 of 2, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
There is a good internal debugger in DOSBOX, accessible by - on numeric keyboard (in debugger enabled builds - not in normal 0.61).
There is no equivalent of CONFIG.SYS in DOSBOX.
There are some programs for dynamic loading of devices, but personally I doubt that you would be able to run SoftICE in DOSBOX anyway.
Mirek
