First post, by Guest
Has anyone out there got Syndicate Wars to run properly under dosbox?
If so, what setting did you use?
The game loads properly and works well in the menu areas, but as soon as I start a mission, it slows right down and is almost unplayable.
I've got an AMD 2100 with 1gb of Ram and the only settings in the config file I've altered are listed below
fullscreen=true
cycles=18000
cycleup=1000
cycledown=100
any help would be much appreciated.
By the way, thanks muchly to the Dosbox team, I've had many hours of playing X-COM: The enemy unknown thanks to them, and It's one of my favourite games of all time 😀
