First post, by videogamer555
The moment I run com or exe file in Dosbox Debugger, I want it to pause execution, so I can start debugging on the FIRST opcode in the program. Unfortunately It seems only by doing alt pause am I able to actually cause the debugger to pause execution (and thus start debugging). Is there any trick that I'm not aware of that would let me cause it to pause execution the moment that either a com or exe file was run, so that I could start debugging the program right from its first opcode?
