First post, by mart.marq
Hello!
This dosbox works fine but I like to close automatically the dosbox window if I end the dos-game.
I created a link on my Win XP desktop to start dosbox and the dos game at the same time.
After I finished the dos game the dosbox window is still opend. OK, I could enter exit but it would be fine if dosbox would close automatically.
Any ideas or is it not possible ?
Cheers
Reply 1 of 3, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Simple. See DOSBOX.CONF, section [autoexec]. You can write there anything what you would write into a BAT file. So you can start the game by one command and use EXIT as another command.
Mirek
Reply 3 of 3, by Markus
You can create as much config-files as you like, use one of them like:
dosbox -conf configfile.
But you can also start dosbox like: dosbox -exit -c ...
And some advise: in your dosbox directory there's a file named readme.txt.
