First post, by markot
In DOSBox debugger, when I start a program with it and press the F5 key, the program will start to execute normally.
Is there any way to pause execution of program in middle of something, so I could then easier check what is currently going on in the code?
Reply 2 of 3, by markot
Just tested it and seems like Alt+Pause works when I press the key combination in the DOSBox window. But when pressing Alt+Pause in the debugger window, it doesn't seem to work.
Is there some way to redefine the pause key combination in DOSBox debugger? When pressing Alt+Pause in the DOSBox window, then it pauses at wrong place because of the Alt key the game uses.
Reply 3 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
No it needs to be at the dosbox window.
You can change the debugger key-combination though. Just use the keymapper to change it.
Water flows down the stream
