First post, by mbellucci
Hi to All, i've a problem when i tryed to configure 2 serial in directserial.
serial1=directserial realport:com1
serial2=directserial realport:com2
I've attached 2 scanner, 1 in com1 and 1 in com2
the scanner in com1 work fine and the scanner in com2 doesn't work (Serial2: Errors: Framing....)
but
if i tryed to remove the serial1 in the config the scanner attached in com2 work fine.
Could you help me?
Reply 2 of 4, by Jorpho
As DOSBox is primarily intended for running games, this is not a scenario anyone is likely to have tested much or is likely to be interested in fixing.
You can start by ruling out hardware problems by creating a second DOSBox installation on your computer. Use serial1 in one installation and serial2 in the other installation, and see if everything still works when you run both installations at the same time.
