First post, by MattSA_01
I see you receive a ton of questions about the key mapper - I'm sorry I have to add another. I am running a Lenovo Flex 3. I am playing Pools of Radiance which utilizes the Home and End keys to navigate vertically through lists which on my computer requires the function key to be active.I have tried turning off hotkeys to invert the selection on keys including a primary command as well as a function purpose. This worked but only on the top strip of function keys f1 through f12. When I tried the function keys for vertically scrolling in POR, I still need the function key depressed (fn + Home or fn + End). This left me at the keymapper.
I have been successful mapping alphabet characters to one another (like in the example of making x produce z). However, it does not seem as if there is anyway of accessing the Fn key from the keymapper - it does not show a Function key on the map and is neither the ALT or Ctrl key (through the MOD keys). I am hoping there is some less obvious answer to this problem. If someone has an answer please send some help. An be specific - I was having trouble with any of the mapping of dual key processes to a single key.
Thanks,
Matt
