First post, by lukeman3000
I like to play games in windowed mode, typically 1280x720'ish size. When I launch a game, the initial small window appears to start at a relatively centered position on my screen (2560x1440), but then once the game starts, the window expands to 1280x720 size without adjusting its position, and the bottom portion of the game window is off the screen, requiring a click and drag to reposition the window.
I am wondering if it's possible to set the position of the dosbox window via config file or otherwise such that when the game launches, it will be perfectly centered on the screen with respect to the game's resolution and the desktop's resolution. I'm sure I could use autohotkey to achieve what I'm wanting, but it would be nice if a solution already exists (or could exist) within DOSBox itself.
