First post, by Guest
ok i am terribly sorry if this was already mentioned in some post but i search for a while and didnt find any answers
i got TeamF1 a old dos game
runs great and all
but when i save a game it saves jumps back to the game
but when i eventually want to load it it seems there is no savegame
i got the same problem with a few other games
is there something i am missing here ?
great work on this nice app btw
Reply 1 of 6, by eL_PuSHeR
Rank Moderator
Moderator
Just a shot in the dark...
If you have copied files from a cd-rom they may have the "Read-only" attribute enable. Open command-line box. Go to game folder and type in attrib -r *.*
Reply 2 of 6, by Cthulhus
Or maybe your games are located on a cd rom drive ... just copy all in your monted folder and type what eL_PuSHeR said attrib -r *.*
Sorry for my poor english ! 😉 But, try to speak french like I'm speak english ! 😀 It's not easy !
Reply 5 of 6, by Freddo
I have the same problems with some games. Like the CD version of TES: Arena. The floppy version (which is now available for free at www.elderscrolls.com) works fine and can save without any problems.
I'm not sure why it happens, but I guess there's a minor bug somewhere that affect some games.
EDIT: This old thread has been bumped and this is no problem with Arena anymore.
Reply 6 of 6, by Knight
I encountered the same problem. In my case, it was placing the save game file in the wrong folder. It saved it in the folder where I mounted. I corrected this by mounting directly to the folder of the game I was saving. You can move your saves to this folder and it might fix it. It will be accessable the next time you run Dosbox and run your game.
