First post, by Gavin
Gavin
Offline
what can i do?
what can i do?
try reading the documentation 😀
in short add -t cdrom when mounting your cdrom drive.
Water flows down the stream
I did, but didn`t help...
It would *much* help to be more specific. What program/game you have that problem with, what you already tried to do etc.
You will have far better chance to get help if you spend a few minutes by making more detailed report ...
Mirek
I get that exact same error with 7th Guest.
Two stones, two crosses, the rest is just icing. - 7th Guest
