First post, by Zakule
I'm having an issue with Ultima7 and Ultima8. By enabling Soundblaster and Adlib emulation I can get both voice and midi music to work but the voice volume is much louder than the midi.
Is there a way within DOSbox to manipulate the Soundblaster voice or Adlib midi volume levels? Either decreasing the voice or increasing the midi would solve the problem.
Any help you can give me is greatly appreciated. Ideally, I'd like a way to manipulate the volume levels via command line so I can include them in the autoexec.
Reply 2 of 2, by teamster1975
Don't forget the general midi patch for Ultima 7 http://www.uo.com/archive/ultima7/
Otherwise the music will be rather interesting! 😜
Patch for Serpent Isle as well http://www.uo.com/archive/ultima72/
