First post, by Yart
Hello,
I'm trying to use Dr. T's MT-32 Editor in DOSBox with my MT-32 (Old) connected via my Sound Blaster Audigy 2 card. I tried adding "delaysysex" to my DOSBox config but I'm still getting a buffer overflow error on my MT-32 whenever I transmit any data to it.
I'm not too sure where to put the command in my config as it's not really documented anywhere that I can find. Right now it looks like this under my MIDI settings.
mpu401=intelligent
mididevice=default
midiconfig=0 delaysysex
Where did I go wrong?
Thanks!
Reply 2 of 3, by Yart
Ah, no I'm not. That would most definitely be the reason then!
I've acquired the Daum SVN build and it no longer gives me the buffer overflow error, but now I get a "Exc. Checksum Error!" All my instruments get changed to the base piano sound and no instrument names change. Though, I'm not sure if that's the fault of DOSBox, or the program itself.
Anyway, thanks!
