First post, by lucky7456969
If I want the dosbox to display the same messages as the original dos software, and among many other things, that make it resemble the look and operations of the original dos...
the caveat is I don't want to boot an image, because when you do it over and over again during the day, it will just slow you down
how is it possible?
thanks
