First post, by Lumina
For a customer, I'm trying to run a DOS program that they use through Dosbox.
I'm not familiar with DOS but I have managed to mount the folder of the program and boot the programs.
But when you enter any values and press enter, it just gets stuck without moving on.
For example, one of the first windows is either one where you enter a number or choose from a menu, but neither move on after entering a value.
Now, I have tested this on a 32-bit W10 and there the program does continue after entering a value, sadly it's not an option to switch the customer to 32-bit windows so I need to figure out why the program doesn't continue in dosbox but it does in a virtual W10.
If anyone could help me figure this out, that'd be great. Thanks.
