Illegal command -exit ?
General information and assistance with DOSBox.
Postby BuckoA51 » 2017-11-25 @ 11:35
Probably going to kick myself this has to be something obvious but, I am trying to use the -exit parameter to make DOSBox close as soon as I'm done playing my game, but instead of that I'm just getting "Illegal command -exit" on the DOSBox command line, what's wrong with my syntax? Here's the line:-
"D:\Emulators\DOSBOX-074-c\DOSBox.exe" -conf "%LOCALAPPDATA%\DOSBox\dosbox-0.74-RallyChamp.conf" -exit
Thanks
play-old-pc-games.com
BuckoA51
Re: Illegal command -exit ?
Postby Osprey » 2017-11-25 @ 20:32
I'm not sure why that doesn't work for you, since it works for me. I don't declare custom .confs on my command line, though, so it probably has to do with that. GOG games use custom .confs, and I see that they end their command lines with "-c exit" (which just sends the regular exit command to DOSBox), so it seems that they couldn't get -exit to work, either. You might just use the workaround that they use or, of course, add exit to your [autoexec], assuming that you're launching the game from there, too.
Osprey
Postby collector » 2017-11-25 @ 23:36
What is in your autoexec section of that conf?
User avatar
collector
Postby BuckoA51 » 2017-11-26 @ 19:36
Lines as follows:-
[autoexec]
# Lines in this section will be run at startup.
# You can put your MOUNT lines here.
mount c D:\ROMs\DOS
mount d E:\ -t cdrom -usecd 0 -ioctl
c:
cd NETWOR~1\RALLYC
RALLY.BAT
I will give -c exit a go too thanks.
BuckoA51
Postby Qbix » 2017-11-27 @ 10:42
use "call rally.bat" instead of "rally.bat"
Water flows down the stream
User avatar
Qbix
DOSBox Author
Return to DOSBox General
Who is online
Users browsing this forum: istellabot [Bot] and 4 guests
