doesen't work
General information and assistance with DOSBox.
doesen't work
Postby jaymak » 2017-11-26 @ 10:05
loaded dosbox. trying to mount a drive (mount d d:\-t cdrom) comes back with d doesn't exists. no matter what drive I enter same result. tried (mount c c:\documents\gwbasic) same thing c doesn't exists. what am I doing wrong
jaymak
Re: doesen't work
Postby Dominus » 2017-11-26 @ 11:35
Drives and folders you want to mount need to exist. Please show a screenshot with Explorer showing these drives and folders. What letter does dour CD-Rom drive have? Which operating system do you use?
User avatar
Dominus
DOSBox Moderator
Re: doesen't work
Postby jaymak » 2017-11-27 @ 21:07
I've been told it has to exist but where? operating system windows 7 pro. my dvd is drive D:, documents on drive C: gw basic is there. I get only one return from dosbox that drive doesn't exist.
jaymak
Re: doesen't work
Postby Dominus » 2017-11-27 @ 21:09
screenshots and screenshots of your dosbox window when the commands fail, please
User avatar
Dominus
DOSBox Moderator
Re: doesen't work
Postby emendelson » 2017-12-01 @ 18:27
Also, you wrote:
mount d d:\-t cdrom
That needs a space after "d:\" (and before "-t-")
emendelson
Re: doesen't work
Postby keenmaster486 » 2017-12-01 @ 20:36
jaymak wrote:mount c c:\documents\gwbasic
Methinks you make too many assumptions. Find out for sure what the actual path of your GWBASIC folder is before attempting to mount it.
Edit: i.e., if you open command prompt and type
Code: Select all
c:
cd \documents\gwbasic
Would it work? I don't think the Windows 7 directory structure works like this. It's probably something like c:\Users\Your User Name\GWBASIC
I flermmed the plootash just like you asked.
Very silly indeed: https://audaxeundum.wordpress.com
User avatar
keenmaster486
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 2 guests
