DOSBox SVN Daum: mouse cause teleport with some games
General information and assistance with DOSBox.
Postby FulValBot » 2017-12-08 @ 17:52
With my mouse i'm getting some random teleportations into Hexen and Heretic games (i think that with Doom is the same) when i move Y and X axis...
this with a Logitech G402 and a Steelseries (i don't remember model...) but NOT with a simple Atlantis (i don't remember model...)
i'm using Windows 10 Pro 64 bit build 1709
edit: all dos games are affected...
FulValBot
Re: DOSBox SVN Daum: mouse cause teleport with some games
Postby Qbix » 2017-12-08 @ 18:09
Daum is quite unstable and by using it, you are on your own.
Try using a non modified build from: http://www.emucr.com/search/label/DOSBox
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby FulValBot » 2017-12-08 @ 18:12
ECE version is already installed but i need to emulate CRT features (excluded the curvature) and i don't want vertical borders...
and i'm getting ECHO problems with musics (fluidsynth mode)
FulValBot
Postby Qbix » 2017-12-08 @ 18:22
well I am not recommending the ECE version in my post. You won't have fluidsynth problems in the linked build as it isn't part of DOSBox.
User avatar
Qbix
DOSBox Author
Postby FulValBot » 2017-12-13 @ 12:24
Ok fixed... with my G402 if i try to use "automatic game detection" option it works bad and jump also with 125MHZ of polling rate; if i try to use "on-board memory" option it works fine when i use 125MHZ of polling rate
i don't know if can works with steelseries model (i don't have tested steelseries software for now)
FulValBot
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 3 guests
