Screen affinity for fullscreen on a dual screen setup under Linux
General information and assistance with DOSBox.
Postby BastetFurry » 2017-12-22 @ 22:42
Hey :)
Having a two screen setup on my Linux box, how do i tell Dosbox to use the left screen when going fullscreen and not the right(wrong ;) ) screen?
EDIT for those who don't want to dig trough the thread:
Put
Code: Select all
export SDL_VIDEO_FULLSCREEN_DISPLAY=0
into .bashrc, your number might differ.
Set your screen resolution in dosbox.conf:
Code: Select all
fullresolution=1920x1200
User avatar
BastetFurry
Re: Screen affinity for fullscreen on a dual screen setup under Linux
Postby Dominus » 2017-12-22 @ 23:22
I think you can’t. It’s an SDL problem
User avatar
Dominus
DOSBox Moderator
Postby BastetFurry » 2017-12-23 @ 01:30
Thats unfortunate, then i go and check if i can hack SDL to do my biddings.
User avatar
BastetFurry
Postby BastetFurry » 2017-12-23 @ 01:46
I am onto something:
Code: Select all
But now i don't get a streched image anymore.
EDIT:
Setting
Code: Select all
did the trick.
Off to place that export into .bashrc :D
User avatar
BastetFurry
Postby Serious Callers Only » 2017-12-23 @ 04:25
The xrandr driver controls if the image gets stretched in linux fullscreen or not. The default is actually to stretch but you can set it to 'full aspect' which stretches preserving aspect ratio.
https://www.reddit.com/r/emulation/comm ... d/drewr16/
I find it highly strange you want to 'stretch' the image, and it should happen by default anyway.
Postby BastetFurry » 2017-12-23 @ 10:02
Serious Callers Only wrote:I find it highly strange you want to 'stretch' the image, and it should happen by default anyway.
Nope, i was getting a pixel perfect DOS shell on my screen, was almost ready to deploy the magnification glasses.
Strangely the Dosbox window stays open, just without content, by the way.
But yeah, works for me now and when someone else looks for a solution it now stands there. :D
User avatar
BastetFurry
Return to DOSBox General
Who is online
Users browsing this forum: SergeyW and 1 guest
