DOSBox Command Line Error
General information and assistance with DOSBox.
Postby Chilly Willy » 2018-1-10 @ 08:14
The command line works fine. Even when I use "-c cycles=500". If I use multiple, like so...
-c cycles=500 -c oplmode=none -c tandy=on
DOSBox messes up and doesn't run the game. Any info would be great.
Thanks!
User avatar
Chilly Willy
Re: DOSBox Command Line Error
Postby olddos25 » 2018-1-12 @ 13:51
What are you trying to do?
Currently mod on several Discord servs and a forum, so you can trust me if you want a DOSBox mod here!
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
EPForums: http://www.epforums.org (as emulationfan)
olddos25
Postby Chilly Willy » 2018-1-12 @ 18:30
Trying to run and open game via command line. It works until I add those three -c commands. If I use just one, it is fine.
User avatar
Chilly Willy
Postby konc » 2018-1-12 @ 19:21
Try removing the oplmode command, it should work. It's not about having multiple commands, it's oplmode specifically.
User avatar
konc
Postby Qbix » 2018-1-12 @ 19:51
well there is a limit to how many -c commands can be given.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby Chilly Willy » 2018-1-12 @ 20:07
konc wrote:Try removing the oplmode command, it should work. It's not about having multiple commands, it's oplmode specifically.
Thank you!
Is there no command line for window resolution?
User avatar
Chilly Willy
Postby konc » 2018-1-12 @ 21:19
Qbix wrote:well there is a limit to how many -c commands can be given.
I don't know why this is happening but "oplmode" in particular seems to have issues. Even alone as a single command messes things up.
Chilly Willy wrote:Is there no command line for window resolution?
Sorry I have no clue, I don't use dosbox like this with commands. I played quickly with your command trying to see what's wrong with it only because you didn't have any better suggestions until then.
User avatar
konc
Postby Dominus » 2018-1-12 @ 23:02
It works better if you create configs for the games and use those configs with Dosbox.
User avatar
Dominus
DOSBox Moderator
Postby Chilly Willy » 2018-1-12 @ 23:51
Dominus wrote:It works better if you create configs for the games and use those configs with Dosbox.
I tried redirecting the config link to one used in the game folder but must have been doing something wrong. As I didn't want to alter the original config. Any clue, via command line?
User avatar
Chilly Willy
Postby collector » 2018-1-13 @ 00:52
You don't need to use a full conf file. Just add the non default settings you want in a separate conf and DOSBox will use defaults for the rest. the main thing you will want is to use the [autoexec] section for game specifics like mounting.
User avatar
collector
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 6 guests
