First post, by PixelLogix
I can't figure out why DOSBox keeps crashing, but when I boot it, it just shows the Status Window, then either crashes or just sits there until it closes itself, and only about 15% of the time does it actually open. I thought it had to do with I had the files on an SD card, but when I installed it brand-new on my hard drive, it does the same thing.
When I get the crash error, the debugger window, named "Visual Studio Just-In-Time Debugger" reads:
"An unhandeled win32 exception occurred in DOSBox.exe [Random 4-Digit Number]. Just-In-Time debugging this exception failed with the following error: No installed debugger has Just-In-Time debugging enabled. In Visual Studio, Just-In-Time debugging can be enabled from Tools/Options/Debugging/Just-In-Time.
Check the documentation index for 'Just-In-Time debugging, errors' for more information."
I don't have Visual Studio on my computer anymore. I'm confused on this.
