First post, by jerfab1
Hi-
I'm trying to use DOSBox to run an old DOS program used for library cataloging called "Minaret". I've figured out how to mount the Minaret directory, and how to get to the C-drive. Next I want to run the program "minaret.exe". But, when I type "minaret" at the command line ("C:\minaret"), I get this error message:
"You must run "SHARE /L:50" before using Minaret: MSDOS 5.0"
I can't figure out how to run this SHARE command and get to the Minaret program. Can anyone help?
Thank you,
Jerry in NJ
