First post, by Undersiege
Hello is it possible to set or to force the dosgames to full stretch in my desktop without the annoing black bars vertical?????
I mean with dosbox normal...non dosbox svn daum.....
Can help me?
Reply 1 of 1, by Azarien
Well, if you set `fullresolution=original` and `aspect=false`, then set your monitor/graphics card to stretch mode, depending on the game you should get that most undesirable effect of stretching.
Keep in mind that DOS games were designed for 4:3 monitors, not widescreens. Stretching will result in distorted image.
