First post, by Yaromir
Won't start at all
CONFIG: Using default settings. Create a configfile to change them
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 149 (MIT-SHM)
Minor opcode of failed request: 3 (X_ShmPutImage)
Serial number of failed request: 49
Current serial number in output stream: 50
Is this something a custom config file could fix? I have ATI Radeon 9500 with ATI's driver.
Athlon XP 2700
1GB ram
VIA sound
Mandrake 10.0
v0.61
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
tricky errors are those. try starting your xserver with different settings
(other colordepth) else use 0.60 and see if that one works.
Water flows down the stream
