First post, by AAGPCN
I am trying to run PC Navigator (copied from my old PC) in Windows 10. When I enter z:\>MOUNT C C:\DOSBoxPr it says "Directory C:\DOSBoxPr doesn't exist". However, it is there under "Documents". How do I do this "MOUNT" in Windows 10??
Reply 1 of 5, by Shagittarius
MOUNT C C:\USERS\(YOUR USER NAME)\DOCUMENTS\DOSBoxPr
Assuming your install is standard just substitute your user name there with no parenthesis. Documents is not the root C.
POST NOT FOUND
Reply 3 of 5, by AAGPCN
Thanks to Shagittarius…!!….It worked after some fiddling!! The "Directories" had to be shortened to 8 characters and I used the DOS commands "DIR" and "CD" to find my way through. I finally had to do it in steps, although there may be a faster way. I did....
Z:> MOUNT C C:\USERS\
Z:\>C:
C:\>ANTHON~1\DOCUME~1\DOSBOXPR>PCN
The "DOCUME~1" is the DOS version of "DOCUMENTS".
This ran the program "PCN" "PC Navigator. I use this for my almanac with my Sextant for marine navigation and star finding!
Reply 4 of 5, by Jo22
Also be careful with paths that include a space, as in C:\Users\Joe Everyone\Documents\DOSBox.
In that case, just type the path in quotes.
Mount C "C:\Users\Joe Everyone\Documents\DOSBox"
Alternatively, you can also use a relative path.
If you have a folder named DOS in the DOSBox directory, just type:
Mount C DOS
Or, if you like to mount a folder named GAME -that's inside DOXBox\DOS- as drive letter E :
C:\> Mount E DOS\GAMES
