First post, by Jens
Hello again! (going mad ... this is my 3rd posting in 24h!)
To get my Win 3.11 network running, i want to process the CONFIG.SYS bootfile, that is used by (real) MS-DOS. It must be loaded prior to anything else (like a keyboard or mouse driver). Unfortunately, Dosbos ignores the file and can only handle AUTOEXEC.BAT commands.
To set up a "real" MS-DOS under Dosbox (is that possible?) would'nt help, because i see no way to (physically) reboot from within Dosbox...
(hope that doesn' sound too weired).
Is there a way to make Dosbox handle system drivers like system drivers?
Thanks for your time!
Jens
Reply 1 of 6, by dr_st
It is possible to get DOSBox to boot real DOS (I've seen numerous references to it).
With that said, there are probably ways to achieve what you want without any of this. DOSBox does not process Config.sys, because there is no need. Everything that Config.sys is used for on a real DOS machine, DOSBox either handles internally via other means, or it simply does not apply.
If you share more details about what you want to do, you may be able to get working alternatives.
Reply 2 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
I think you NEED to boot in DOSBox for getting WfW Networking to work.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 6, by dr_st
I found his other thread:
Online with WFW3.11
If it's true that WfW 3.11 physically requires IFSHLP.SYS in memory to allow networking, then you are probably right that booting real DOS inside DOSBox is the only way.
Reply 4 of 6, by Dominus
DOSBox Moderator
You actually even need a special build of Dosbox with some network driver built in. Libcap or so...
Reply 5 of 6, by Jens
Online with WFW3.11
Yes, IFSHLP.SYS is the bad guy. "Your network adapter could not be started, please check etc..."
I've read about making images of a bootable Dos/Dosbox and uuuuuuuuhhh! Far too technical for me. So I'll better stay offline (ebay would'nt accept my extra-cool 1993 Mosaic-Browser anyway) ...
Thanks!
Jens
