First post, by Harald of Alsius
Hey all,
Because of my visual impairment, I play most games using a memory hacking tool which allows me to adjust game speed by messing with CPU usage. After discovering that this method doesn't work with DOSBox, I tried using the Ctrl+F11\F12 commands, but those made the game (Star Wars: Dark Forces) quite unplayable, making it feel as if it would lag instead of giving me a "slow motion" effect. So my question is, how should I configure DOSBox in order to get a slower, yet playable experience?
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Dark Forces runs in protected mode, so with default settings in DOSBox you'll be using the dynamic core and max cycles. Ctrl-F11/F12 with max cycles results in a percentage of max, which may not be ideal for your purpose.
You can use the core=normal setting in DOSBox, and this by itself will make the game slower than dynamic core.
You can use a cycles=20000 setting, or some other amount of fixed cycles, to control game speed. You may find that the game works more smoothly with a cycle limit, e.g. cycles=auto limit 20000, so experiment.
Restraining the CPU speed will definitely make the game run slower, but it won't necessarily maintain good playability.
Reply 2 of 2, by robertmo
Lowering cycles will only lower the fps and keyboard/mouse responsiveness witch will make the game even harder to play.
But you can slow the game down by rising the cycles above the amount your computer can handle.
