First post, by Guest
Q: I would like to change the memory size/cpu speed/ems/soundblaster IRQ.
A: This is possible! Just create a config file: config -writeconf dosbox.conf .
Startup your favourite editor and look at all the settings present. To
start DOSBox with your new settings: dosbox -conf dosbox.conf
Hey all, I was just wondering if anyone could clarify for me something from this part of the readme. I'm not really clear on where exactly to enter this last line "dosbox -conf dosbox.conf" where does that have to go in order to work?
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
from within dosbox you type the
and from the shell you type
Water flows down the stream
Reply 4 of 4, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Very simply said, the "shell" is basically a command line in your host operating system (Windows, Linux,...). If you you start DOSBOX by clicking on a shortcut (icon), then modify its properties (right click on icon).
Mirek
