First post, by dannylan
(please ignore an identical previous posting where I posted as a "Guest", please reply to this one... Thanks!)
Hi!
I have downloaded "DOSBox 0.61" because I need to run a very simple .exe program on my Mac running OS 10.3.4. The problem is that I have never used DOS in my entire life so when the DOSBox terminal window opens up with "Z:\" I don't know how to tell it to run the .exe file sitting in my desktop...
Actually, there are two files, one is an .exe and the other has ".lwp" (??) as the suffix...
Thanks for your detailed help.
Best!
