First post, by analytix
I am not a gamer. I have many (hundreds) of my own programs, written in True Basic for DOS environment. Currently running on Windows XP, but now I have to switch to Windows 10. Have done some DOSBOX trials, which "work" but with stammered hesitations. Sometimes 3-or-4 seconds, or hesitation, up to 30 seconds (at a guess). In hesitation, there is no CPU processing while the system just waits...then suddenly zips through a bunch or work till next stammer pause. Any solution to this stop-and-go?
P.S. I've also tried vDos, which doesn't have the stammering problem, but crashes when encountering program statements to re-dimension a vector or matrix ["MAT REDIM (x)" in True Basic]. If you know the answer to the vDos REDIM problem in vDos, DOSBOX would be not relevant and I'd be home free.
Thanks for any help
