First post, by MitAvras
Hello! I have a problem with DOSBox. After installation, I can't change the options. The file 'stdout.txt' always displays an error message telling "tried creating C:\Users\??t????a??? ?ß???\AppData\Local\DOSBox\dosbox-0.74.conf. but failed." Does anybody know if I can change the path where DOSBox creates the Configuration File?
    stdout.txt
    94 Bytes
    53 downloads
Reply 1 of 2, by DosFreak
What is the username of your profile in Windows?
You can have DOSBox use a config file outside of the profile by putting dosbox.conf in the same directory as dosbox.exe
Make your games work offline
Reply 2 of 2, by olddos25
I think it is a problem related with the characters used for the profile name.
Just another user that likes old OSes and videogames, nothing interesting to see here...
Other places to find me:
DraStic: http://drastic-ds.com (as dsattorney)
