First post, by Guest
Guest
Offline
I downloaded Dosbox 0.61 and installed it.
Everything went fine with no errors or anything special...
But when I start dosbox.exe:
Opens 2 windows with titles 1. the dosbox.exe and 2. SDL_app.
Dosbox in the background and SDL in front, SDL is empty window and dosbox shows:
CONFIG:Loading settings from config file dosbox.conf
Fatal Signal: Segmentation Fault ( SDL Parachute deployed)
And instantly closes both windows (even though ran from cmd)
[this all happens in like 2s]
OS = win xp
CPU = AMD TB
Any ideas what's wrong?
and yes, i have tried to install it several times 😀
