First post, by Smack2k
Finally decided to get into DOSBOX and set it up on my PC....
Doing initial setup stuff and doing a simple mount command. Mounting C to where I wanted it was fine, but when I do a
mount D E:\ -t cdrom
I am getting a Message Not Found error
E:\ is definately my CD-ROM drive. Doing a mount -cd even lists E:\ as being found...
I wanted to put this mount command in my .conf file for initial loading, but not working....any reason why this is happening?
Or do I have to have a CD in the tray and cannot mount it in the .conf file so its just there each time I start DOSBOX?
