Mouse capture not working in Linux with Xorg 1.20.x
General information and assistance with DOSBox.
Re: Mouse capture not working in Linux with Xorg 1.20.x
Postby Dominus » 2018-11-11 @ 17:09
I think you should aim at the latest from the 1.2 branch
Edit: sorry, my mistake. The SDL-1.2.15 is for the target folder not the tag ;(
User avatar
Dominus
DOSBox Moderator
Postby swashdev » 2018-11-24 @ 08:07
I took a look at this thread because I was having this problem with my new Xubuntu system (Ubuntu version 18.04.1) and someone mentioned that the Ctrl+F10 keypress was getting intercepted by the window manager. Looking at the options for my window manager, I could see that the Ctrl+F1-F12 key combinations were all used to switch between workspaces (also known as virtual desktops) and so by disabling these keyboard shortcuts in the window manager DOSBox was able to use the Ctrl+F10 key combination to capture my mouse.
In Xubuntu this is done by simply opening the Settings Manager from the Applications menu, clicking on Window Manager, going to the Keyboard tab, and selecting the Workspace 1 - Workspace 12 shortcuts, and pressing the clear button to remove the keyboard shortcuts. How you would do this in other versions of Ubuntu is beyond me, but this workaround fixed the problem to my satisfaction.
swashdev
Postby gandhig » 2018-11-24 @ 14:36
swashdev wrote:I took a look at this thread because I was having this problem with my new Xubuntu system (Ubuntu version 18.04.1) and someone mentioned that the Ctrl+F10 keypress was getting intercepted by the window manager. Looking at the options for my window manager, I could see that the Ctrl+F1-F12 key combinations were all used to switch between workspaces (also known as virtual desktops) and so by disabling these keyboard shortcuts in the window manager DOSBox was able to use the Ctrl+F10 key combination to capture my mouse.
Thanks for sharing your experience. Please note that this was one of the issues, but not the main problem mentioned in this thread. It pertains to Ubuntu version 18.10 with X.org version 1.20. You may be aware that Ubuntu version 18.04 comes with X.org 1.19.
We are trying to get to the bottom of the issue w.r.t either SDL-1.2.15 or X.org 1.20. Please bear with us for the delay. Hopeful of getting a temporary fix...at the least.
User avatar
gandhig
Location: Unknown...yet. Triangulating inside...Level 1
Postby Qbix » 2018-12-11 @ 15:46
Added a workaround in 4177.
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby DosFreak » 2018-12-11 @ 17:02
Good work guys. Sorry I didn't help more. Was on leave and then working on getting a new job which I got!
I need to check the Readme to see if we have the CTR+FX issue mentioned in the Readme or not, that's always been an issue.
The below was commited three weeks ago so just in case it messes things up whever the distros get it:
https://gitlab.freedesktop.org/xorg/xse ... equests/77
User avatar
DosFreak
Postby wanderyr » 2018-12-29 @ 05:28
You guys are amazing. Thanks for your hard work.
I see the diff file for this patch on your main page. Were you intending to build binaries any time soon?
If not, I guess I'll learn how to build linux software!
Thanks again,
wanderyr
P.S. Congrats on the new job, DosFreak!
wanderyr
Postby Qbix » 2018-12-29 @ 08:51
You have to check with your distro, we don't provide linux binaries ourselves.
I know that debian has the patch included in their testing and unstable distro.
User avatar
Qbix
DOSBox Author
Postby wanderyr » 2018-12-29 @ 09:35
Thank you, Qbix. Happy New Year :)
wanderyr
Postby Thorwald » 2019-10-07 @ 15:32
I got the same problem.
Xubuntu 18.04
It happened circa after upgrade to kernel 5.0
No mouse capture.
ALT-ENTER kill the DosBox window instead of making it full screen.
CTRL-F12 not working because mouse is not capture.
I have eliminated workspaces as suggested in one of the posts above but to no success.
I can open DosBox box in top-left corrner but when I press Full Screen it doesn't work.
Thorwald
Postby DosFreak » 2019-10-07 @ 16:42
Does that distributions repo have the version of DOSBox with the committ 4177 or later?
According to this the package was last updated Nov 2017 and the fix for this issue was commited in Dec 2018.
https://launchpad.net/ubuntu/+source/dosbox
Options:
Ask the maintainer to update the package
Revert back to Xorg 1.19.
Use a newer version of Ubuntu
Compile the latest DOSBox
Possibly download the package for the latest Ubuntu and use it on your current version
User avatar
DosFreak
Previous
Return to DOSBox General
Who is online
Users browsing this forum: No registered users and 2 guests
