First post, by Synetech
Hi,
I've got problem with DOSBox. I installed DOSBox 0.61 then ran it. It started up fine but it immediately started using 100% of the CPU and continued to do so until I ended the program. It uses 100% CPU not matter what, even when it's idle, doing absolutely nothing at the Z:\ prompt. I have not made any changes and it does this. I tried changing the frameskip and cycle settings but that did not fix it.
DOSBox looks to be great but it's completely useless if it uses 100% CPU when idle. I tried running a couple of games and they were terribly slow which is not a surprise since DOSBox is normally putting a full load on the CPU.
Any ideas why it's doing this and how to fix it?
Thanks.
FireBox @ Synetech
