First post, by Avenger
I've been using DOSBOX for a few years now and for the sake of consistency would prefer if I was able to open folders and run executables with spaces in the name.
Is this possible?
I've yet to find a command that works.
Cheers.
Reply 1 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You can mount folders with spaces but then you are limited to Dos conform folders and file names
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 8, by Avenger
Alright,
Let's say I want to play a game and the executatble is located in:
C:\Program Files\DOSBox\Games\Terminator\Future Shock\Future Shock.exe
What would the command be to run this without having to eliminate the spaces in the name of the last folder and the executable file?
Reply 3 of 8, by Dominus
DOSBox Moderator
You cannot. Keep the games as they were and don't add spaces to folders and exe. Dos naming scheme of 8+3 (filename+extension)
Reply 4 of 8, by Zup
You can't. DOS rules (back in the day) were 8.3 names without special characters (i.e.: dots, spaces).
You can do something like:
mount f "c:\program files\dosbox\games\terminator\future shock\"
So your game directory will be mapped to f drive, but then you would have problems to run that "Future Shock.exe".
I'm selling some stuff!
Reply 5 of 8, by Cyberdyne
Volkov Commander can open directories with spaces. I dont know if Norton also does.
Reply 6 of 8, by Dominus
DOSBox Moderator
It might not work IN DOSBox as DOSBox won't show the directory with spaces correctly so the directory it want to open might not exist...
Reply 8 of 8, by Dominus
DOSBox Moderator
Yes, because the file name is "future shock.exe" not "future s.exe" or "future~1.exe", so when you enter those the exe is not found.
