First post, by JoãoBC
Guys, sorry if this is not the correct session.
I do not know for sure if it is a request for recourse, or reporting on error.
I use DOSBOX SVN DAUM.
It Works very well.
When I switch the screen to 50 lines, the blinking cursor disappears.
Everything works fine, I just get "lost" due to lack of cursor.
I wonder if there is any app, or change in configuration for the cursor to appear.
Sorry for English, I'm using the google translator.
Reply 1 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The Daum build is not supported here. On a side note, the problem you describe was probably inherited from official source, and has been fixed in SVN. Daum has not been updated in a long time, and therefore does not include the fix.
Reply 2 of 3, by gdjacobs
The Daum build is not supported anywhere, really. The original maintainer no longer works on it and nobody has taken over in his place. If you want to continue using Daum, any problems you find will almost certainly remain unfixed.
If possible, it's probably a good idea to move to a DOSBOX release which is currently maintained and stays up to date with the mainline source tree. Not all the features from Daum have been brought forward, so I'd recommend taking stock of the features you actively use and which of those you feel you definitely require.
