First post, by Pyman
I get this eror when trying torun a program with in the dosbox, help?
Fatal Error in Expanded memory: error 132 deteceted in module A while
executing
executing
We need to know the name of the game, otherwise nobody can help you ...
Mirek
Err Sorry its an old application not a game.. does this matter? I'm trying to the run the app from another network share on my home network.
It does not matter that it is an application, but it matters that we do not know it.
We have no idea what that error means (just the author of the original program knows that ...). There is a problem with expanded memory (check that it is switched on in DOSBOX.CONF !), but that does not tell us anything very usefull...
Mirek
The application is cal PS2000 and yes extened memory is set to true in the conf file. The appication is produce by Rebus software, regards pyman
