3DFX
First post, by legluondunet
Hello,
could you tell me what is the best solution to play 3DFX dos games?
Dosbox can simulate a 3DFX graphic card?
Thank you for your help.
Reply 1 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
The best solution: a real PC with a Voodoo card.
2nd best is Qemmu, I think or PCem perhaps.
Lockstock Dosbox does not yet have 3dfx support. There are patched versions however, but I'm not keeping track which actually do have it.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 6, by gdjacobs
Dosbox ECE has it, just don't bother the main Dosbox devs with issues related to it. YP80 will be your prime contact as he maintains the fork.
Reply 3 of 6, by appiah4
I do commend DOSBOX-ECE for doing a good job of it but I can't help but feel like it's.. let me rephrase, I would rather stick to the official DOSBOX branch as these kinds of heavily patched branches tend to not end well.
For emulating a Voodo PC I've found PCem to be a much better choice, personally.
Reply 5 of 6, by DosFreak
There are but there are very few DOS games that require 3dfx to play the game and for those that offer both options it's debatable if 3dfx is the better option so it's not a high priority compared to supporting all the other DOS games that don't need it.
Make your games work offline
Reply 6 of 6, by leileilol
Also "the best" is subjective because there's always at least one that claim that fantasy unlocked timings doing 32-bit color in HD resolutions on a Voodoo Graphics through wrapping wrappers to play crappy 3dfx versions of Blood/Shadow Warrior for example, is "the best way" etc.
