First post, by Guest
The readme says:
If no configfile is specified with the -conf switch, DOSBox will look in the
current directory for dosbox.conf. Then it will look for ~/.dosboxrc (Linux),
~\dosbox.conf (Win32) or "~/Library/Preferences/DOSBox Preferences" (MACOSX).
I have Win32, which means
~\dosbox.conf
but what is "~"?
I tried simply putting it in the root (i.e. c:\), but it doesn't find it.
I tried putting it in c:\windows. Still didn't find it.
I've even tried putting it in numerous places within "c:\documents and files" (my user, all users, etc.).
So where is this "~"?!
Reply 2 of 6, by guest
Ok, once again, we're talking about Win32 here...
What's "$home" in Win32?
Reply 3 of 6, by MiniMax
Rank Moderator
Moderator
C:> set H
HOMEDRIVE=C:
HOMEPATH=\Documents and Settings\MiniMax
C:> set U
USERDOMAIN=MINIMAX
USERNAME=MiniMax
USERPROFILE=C:\Documents and Settings\MiniMax
so your home directory will be %HOMEDRIVE%%HOMEPATH% or (a little easier) %USERPROFILE%
Or mayby you have to create a real environment variable (press Windows-button + BREAK, select the "Advanced" tab, click "Environment variables") called HOME and point it to where you want it to look?
_________________
Reply 4 of 6, by Guest
You were right the second time. It works if you manually create a variable called home.
But come on, what kind of concept is this? You don't expect every one who installs Dosbox to do it him/herself, do you? Not to mention that no Win32 user can understand that readme. How should I have known to create it?
Why don't you use the installation to change home into something that we choose or at least change the default one into something that actually exists (like homedrive)?
Please don't be angry or something. I just thing it's kind of strange.
Please consider to make such a change.
Reply 5 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
quite simple
on windows dosbox is usually started by it's shortcut
that one has the configfile in it (-conf c:\program files\dosbox-0.61\dosbox.conf)
On linux there is no concept of shortcuts. so it's for them that it's used.
there everybody has a $HOME variable.
So it's mainly for *unix/*bsd users not win32 users
Water flows down the stream
Reply 6 of 6, by Guest
The -conf shortcut is only good if you don't want to use any conf files other than the global one...which kind of ruins the entire concept of customization, isn't it?
