First post, by Peter Swinkels
As stated in the subject line, I am trying to use the DOSBox debugger on a laptop which does not have a full keyboard. This means there's no pause key to be found (and no it's not FN+some other key) and I am unable to pause DOSBox for debugging.
While changing the keybindings in DOSBox does give me a pause key the debugger doesn't seem to recognize it. Other than finding an external keyboard to use, I see no other solution. Does anyone have any suggestions?
Thank you.
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
